Does anyone feel really good about tackling a new fix on the car? Something you thought was hard and never did before? First brake job or similar? I think its fulfilling.
I'm well past that.Does anyone feel really good about tackling a new fix on the car? Something you thought was hard and never did before? First brake job or similar? I think its fulfilling.
NOT if I am fixing factory/design stupidity. Or really some other half posterior butcher job. Most of the time if I am doing a modification or routine maintenance.Does anyone feel really good about tackling a new fix on the car? Something you thought was hard and never did before? First brake job or similar? I think its fulfilling.
Absolutely! My wife's GM SUV had the water pump fail at about 85k. I was upset....1) The 2008-2010 has a special warranty covering the known defect, ours is a 2011 2) we had an extended warranty that expired 8 mos. prior. So I set about to DIY, watched about 5 YouTubes. One was the excellent one--a normal "dad" who showed how to do it, in detail. One tip was you don't have to loosen motor mounts, I promise you, you can take it out, it will fit. Another tip on amazon? Please use RTV even though the factory doesn't require it--you don't want to do this job twice as I did.Does anyone feel really good about tackling a new fix on the car? Something you thought was hard and never did before? First brake job or similar? I think its fulfilling.
