If you want a plinker load for the bolt '06s, check out Hodgdon H4895. It is recommended for bullets from 110 to 208 gr. The reason I recommend it to you is that per Hodgdon, it can be safely reduced to 60% of the full power load. There is a pdf on their site which gives the formula in full.
