I created this to clarify the myth that "5w-30 and 0w-30 are too thin!"
This was originally a supplementary write-up for my GC FAQ.
If you see any errors or have suggestions, please PM me.
(I'm sure there's room for lots of improvement.)
Thin Oil Myth
Created: April 10, 2006
Disclaimer:
All the temperatures here are in celcius.
Short answer:
0w-30 and 5w-30 can be thicker than 10w-30.
Long answer: Read below.
Really Basic (but not so intuitive) information:
Back to the point, "Why isn't 5w-30 or 0w-30 thin?"
I think a real-life example will help.
Finally, my concluding remarks.
Credits:
Thanks for reading!
Thin Oil Myth
Disclaimer:
Short answer:
- I'm sure we have all seen 5w-30, 10w-30, 10w-40, 20w-50, but what does it mean?
When talking about viscosities, you must state the temperature.
Lets break this up into two categories: hot and cold.
- Xw-20, Xw-30, Xw-40, etc (HOT!)
This is your oil's hot viscosity. The viscosity is measured @ 100c.
This number is relative when the engine is warmed up.
The most common unit is cST. The larger the number, the "thicker" the oil.
- Examples
A "30" weight is between 9.30-12.49 cST @ 100c.
A "40" weight is between 12.50-16.29 cST @ 100c.
Here's a table. - Examples
- 0w-XX 5w-XX 10w-XX, etc (COLD!)
This is your oil's cold viscosity. A 0w, 5w, 10w, etc, are not measured at the same temperature!
This is number relative when starting your engine.
The most common unit is cP. The larger the number, the "thicker" the oil.
- Examples
A "10w" weight must have a MAX viscosity of 6600 cP @ -30c
A "0w" weight must have a MAX viscosity of 6200 cP @ -35c
- It never gets to even -15c here, so what's the start up viscosity for me?
Great question! A lot of us don't live in super cold temperatures.
Unfortunately, the oil companies don't have to tell you. All they need to specify are the extremes.
- Can I know an oil's viscosity at different temperatures?
Yes! Aside from actually measuring the viscosity, you can do some calculations.
With a viscosity calculator and enough data, you can piece a graph together.
You can usually get all the data from the manufacturer's datasheet.
Take the calculator with a grain of salt. They are decently accurate in most temperatures, but I wouldn't trust them below -15c.
- Why do they measure the cold and hot viscosity (cP vs cST) in different units?
Something about dynamic vs kinematic viscosity.
I won't go into detail here, because I haven't researched this.
- Lets compare Mobil1 5w-30 to Mobil1 10w-30.
- First the Hot (100 c) setting
Straight from Mobil1's datasheet (Looked on April 4, 2006):
- 5w-30 = 11.3 cST
- 10w-30 = 10.0 cST
Looks like the 5w-30 is thicker! (Notice how both oils are a "30" weight)
- Now lets look at the cold setting
Based on the 5w and 10w specifications:
- 5w-30 = 6600 cP or less @ -30c
- 10w-30 = 7000 cp or less @ -25c
Looks like 5w-30 is thinner than 10w-30!
- We can conclude that:
- 5w-30 is thinner than 10w-30 at -25c.
- 5w-30 is thicker than 10w-30 at 100c.
The above implies that 5w-30 thins out less than 10w-30 as temperature increases.
- Still confused? Maybe this graph will help.
The graph is just a learning tool, don't use it as an actual reference.
- Reminder: this example refers to Mobil1. If you're curious about other brands, you will have to look at their datasheets.
- My main points are:
- 5w-30 can be thicker than 10w-30.
- 0w-30 can be thicker than 5w-30.
- Unless you have tools to measure viscosity, you need to at least:
- Specify a temperature.
- Check the manufacturer's datasheet.
- The cold viscosity tells you NOTHING about the hot viscosity.
- Some things you might have noticed:
- I haven't claimed an Xw-30 to be thicker than an Xw-40. At least at operating temps, any Xw-30 will be thinner than any Xw-40.
- Everything I have said can apply to other weights within the same hot viscosity.
- It's possible for a 0w-40, 5w-40, or 10w-40 to be thicker than a 15w-40 at certain temperatures.
- It's possible for a 0w-20 to be thicker than a 5w-20 at certain temperatures.
- MANY other factors about oil were not discussed here. Please don't base your oil preference on viscosity numbers only.
- When in doubt, follow your car's manual. At least you won't void your warranty that way.
Credits:
- BITOG, 'nuff said.
- AndyH for the cold viscosity table.
- 427Z06 for the calculation info.
- The countless number of names I have forgotten.
Thanks for reading!
