Originally Posted By: SuzukiOldTimer
I'm appalled, by just how few drivers even know what a FOG light is supposed to be. Super bright Blue or White lights are NOT FOG LIGHTS! Period! They are either Rally Lights or Driving Lights.
FOG Lights are Amber (Yellow) so they cut through fog instead of reflecting back at you, off of it. They must be mounted low, like below the front bumper and aimed low so they illuminate the road directly in front of you. Also, to be effective, when the Fog Lights are turned on, the headlights should be OFF.
JFYI
From all of my reading and experience over the years, the colour does not determine if it's a "fog" light or a "driving" light - the beam pattern does. I'm not arguing that warmer colours scatter less in fog and improve visibility - I agree in that regard.
A "fog" light is typically low on the vehicle and is aimed with less declination than most headlights. It has a WIDE beam pattern with a sharp cutoff. It should not shine in the eyes of oncoming traffic whatsoever and is meant to shine flat along the road surface and off to the shoulders.
A driving light can be high or low and has a narrower beam. It may have no cutoff whatsoever like a high beam lighting pattern. A "driving light" is just another light that shines ahead of the vehicle with no specific purpose.
Daniel Stern lighting has info on aiming foglights at
here. It also has the following commentary on fog lights:
Quote:
Fog lamps produce a wide, bar-shaped beam of light. Horizontal aim is much less critical than it is with headlamps. The fog lamps should be pointed straight ahead, not leftward or rightward.
So, if a vehicles extra lights produce a very wide, uniform light pattern with a very sharp, level cutoff at the top - they are FOG LIGHTS. Otherwise, they are something else.
