F-14 Questions Answered - Ask Away
Astro, out of curiosity what was the success rate of the mile long swim in full gear? Were there any time restrictions? That had to be an absolute bear!
I think we had a pretty good success rate in my class - a couple of guys had to repeat it because they took longer than the hour alloted to complete the swim. Now, to be fair, you had to be athletic to even get into the Navy flight training program. You had to meet minimum requirements for a 1.5 mile run, pushups, pull-ups and sit-ups. The recruiters warned you that there would be lots of swimming as well.
One friend of mine, an AOCS classmate, was a “swim rock”. A former football player at Tennessee Tech, he just couldn’t relax in the water. He would tense up and sink like a rock. He failed the drown-proofing over and over. He had to attend lots of remedial swim classes, but eventually made it. He was smart, determined, and a very competitive athlete, but not a great swimmer. Barry Eugene Wilmore.
The world knows him now as the astronaut - former space shuttle pilot, International Space Station Commander, and part of the crew that was accidentally stranded in space for 9 months by the Boeing Starliner test flight.
But back in 1986, Barry was a classmate who needed help meeting the swim standards.
https://en.wikipedia.org/wiki/Barry_Wilmore
I understand - we had the baro chamber, and had to deal with hypoxia at 25,000 feet, which the USAF also did.
Forget hypoxia, the worst part was when all your academy classmates are popping off with more gas that a Taco Bell management convention.
The funniest part was all the female cadets joining right in with no effort to try to contain the uncontainable.
The ejection EPT that we had was similar to the USAF - but in talking with my USAF peers - there was nothing like Navy Water Survival training, which was important immediately following the ejection.
The closest thing to water survival we got at the Academy was just a 10m jump off the high dive in BDUs, followed by having to swim a given distance underwater, make a "hole" in the "burning fuel at the surface" so you could pop up to breathe and then demonstrate static floatation by inflating your BDU blouse and securing it around your neck.
Hardly comparable to a cockpit dump like they do at Pensacola.
Classmate of mine cross-commissioned to the USMC and flew F/A 18s. He didn't like the yayhoo USAF mindset exemplified by many of our cadet peers set on flying and wanted to fly with people he perceived as more serious or professional.
He ended up invented a cool widget to allow high-def LITENING pod imagery to show up on a cockpit IPad.
He's apparently a "Phone Colonel" now and apparently is running a test detachment at Yuma, might be retired now like many of my classmates. That's him front and center with the properly blocked cover. Good dude, I'd say he'd give you the shirt off his back but that's a massive understatement. He'd take a bullet for you and then make sure you were safe before giving himself permission to bleed.
Astro, your story about Barry reminds me about the scene in the Coast Guard movie with Kevin Costner, "The Guardian". The class was in the pool treading water, and the strongest guy in the group, who was built like a weightlifter, didn't last at all, and was booted.
Costner told the class, "muscle does not float!".
O M G - this is Truly Great stuff - could easily be Must Read for Air Force Pilots to be . .
I use to Party with Bunch of those Pilot Guys always getting into some Pranks ..
Security Guys were all on My Floor also ..
Anyhow 3rd Time I Built My Bike to be a Beast after Breaking Motor in came back from Florida to GA early Spring time
still had some Cool Nights . . I had heard we had a semi Broken F14 on Base came in to be Repaired ..
Guys that Tweaked & Rebuilt all Engines & Helped Me with Part of Build on My 1200cc Super-Glide ( Think ) Machine Shop
with Unlimited capabilities . .
OK so Bike was Cranking out Bad $SS HP & Tq. 12.5:1 Compression & so many other Tweaks - I'd Fill another 2-3 Paragraphs . .
Ported Twice - Once Before Custom 4 angle Grind on Valves while Lowering Valves .060 Deeper into Head - to
Reduce Spring Tension `\ : - ) for Faster RPM Climb . . , so Ported again & Added Super Feather Light Forged Pistons .020 Over Bore ..
Full set of Andrew's Drag Gears - Taller then Close Ratio up 3 Teeth in Front - Down 4 in Rear Drilled Out Sprocket & Brake Rotor
Dropping some real weight for more Spin Up ..
OK enough said I Found My way down to Runway - as I Heard Testing was being Done & F14 was Leaving Next Day ..
I get down there and Watched as Turned right next to Big Backing Plate approx 14ft-16ft wide lower half concrete want to
say 7ft High . . could have been even Higher - Light Up After Burners Blue Redis Cones stretched out what seemed
Like 18ft or More into Night - was still - like 160ft away on service road .. approx 1am in Morning , so
something Secret was Going Down ..
After First 2 Test _ I decided I'd just have a Go see what Speed that Thing could Do . .
I Lined Up and Pulled Up along Side on 3rd Test about 20ft Off Planes Right Wing - Cockpit was Lite - He was Watching
I just Rev Bikes Motor few Times and Nodded Down Run way . He first gave Funny Look - Like what Hell . .
Then He gave Me a Salute & I Gave 1 Back - I Rev More & More - He Throttled Beast Way Up - Brakes Locked , Plane Sliding Forward
He Released & Mod Harley Clutch Dug In - Tire Spinning - We both Off 1st Gear - Out Past Nose Tip , second Gear Pulling away
3rd I'm Gone , but I able to Hear Engines Coming 3rd Gear Tops out around 115 mph ~ Man ~ that Beast Blew By Me with such
Shock Wave ~ Bike went 8ft to right then Sucked Me back 6ft to Left to where Beast was 1/2 sec. ago - He's Air Born ..
Turns Out Next Day they had a send Off -we went down to flight Line to watch - this F-14 goes like 220-250 ft Off in Air
Pushes Engines to even Higher Power Pulls Nose Up - into - Straight Up & Never Gets Out of It ~ Just Climbs Up , Up
BAM - Big - Sonic Boom still Going Straight Up into Clouds .. Broke Sound Barrier I'd say at around 800-900 ft Off Ground
Maybe 1000 ft Loudest Sonic Boom I ever Heard & I have Heard Many . . Kept Climbing watch had to be 20,000 ft & Still Going
Heard Later from Guys in Machine Shop that Both Engines were Cranked Up as Captain of Air Craft Carrier wanted Special
Early Alert Plane that could get Highest Point Fastest & Ready before anything else on Planet . .
