A tp filter does a very good job. The media is cheap. The service life isn't that long though.
Depending on the size of your sump, it takes a while until the sump is "mature". The problem, if you call it one, is that when oil was Group I and recommended OCIs were 2000 miles or less, then they really saved some cash plus did a great job on filtering. Now you have oils that can last a very long time in comparison, so you're payback is a bit different. The roll will saturate at some variable rate depending on how much you introduce in combustion byproducts (and other stuff) into the oil. Most do 3k/3m tp filter changes. I imagine you could manage a fuel consumption component to change this number..but anyway, effectively you'll be dumping a very clean quart of oil in the servicing. Not such a bad deal if you're under 12k year. 4 quarts of oil and 4 rolls of tp ..forever. If you're up in the 18k a year bracket ..then you're doing 6 quarts a year ..and you're starting out with a new sump. So, you're doing your next (assuming 6 month OCI) oil change piecemeal.
If you're a 3k/3m type ...lots of pluses to it. If you're not trapped in the 3k prison, then you have to rely more on the finer filtering aspects of the filter for value.
Just factor your sump size plus one quart for the tp filter and then reduce the original sump by that percentage at each 3k interval. It take s long time to reduce the original sump to lower than the new oil your adding. The larger the sump ..the longer it takes.
Let's say a 4 quart sump and 1 quart for the filter
5 quarts new oil new filter
first change
80% original sump 20% new
64% 6k/16%3k/20% new
etc..etc..etc. You'll decrease all the % to .8 of their last value on each tp change. It takes a while to reduce the original 5 quarts to below 20% (the new add).
You can sorta factor your composite sump "age" if you so desire.
Great filtering. Cheap media. Shorter life span.
I'd say that if you were on the shorter end of the annual mileage spectrum they would work well. If you're on the higher side of the annual mileage spectrum then an Amsoil unit would be more suited to your needs.
