Usually it's only euro in 5w40. You'll have no issues.Thank you everyone for the responding. I want to use 5w40 on my 04 Tundra but can only find the European formula in that weight, yes I know the oil for my truck is 5w30 but I have used 10w40 with no issues.
That particular 5W40 is so-called "light" XW40 oil. HTHS should be around 3.7, so basically it is overkill for any American engine unless we are talking Corvette etc.Thank you everyone for the responding. I want to use 5w40 on my 04 Tundra but can only find the European formula in that weight, yes I know the oil for my truck is 5w30 but I have used 10w40 with no issues.
Wdym by overkill?That particular 5W40 is so-called "light" XW40 oil. HTHS should be around 3.7, so basically it is overkill for any American engine unless we are talking Corvette etc.
It won't do any harm, it will provide better protection, but you might suffer bit of MPG penalty which you might or might not notice.
European oils in general have higher HTHS than your average synthetic oil (ILSAC). While their KV100 is not necessarily that higher, HTHS as consequence of much better base stocks is. Also, they pack much more ZDDP. That particular M1 5W40 has ridiculous additive package. It will clean engine like no other.Wdym by overkill?
No, it won’t cause any adverse effects like that.Interesting, my truck has 240k miles, no oil leaks, I wonder if I will develop any leaks after using that euro 5w-40 especially if it has the amount of cleaner( additive) you’re talking about.
Oh no, should I use a different 5w40 brand? Anyone else has an input about it?Full SAPS (like the M1 pictured in OP) is not good for an engine that burns oil, this will shorten the catalytic converter life. Main reason I no longer use it in my VQ35DE engine(s).
Does your vehicle consume oil, are you low when you do an oil change? If not I don’t think there is much to worry about.Oh no, should I use a different 5w40 brand? Anyone else has an input about it?
I’m in North Texas during school year and in the Dallas area during summers, we have cold winters and pretty hot summers. I wanted to go back to a 5w but stay with 40, I feel like a 5w40 would be great for my climates.The only non European oil I can think of in 5W40 for gas engines is Chevron Delo 400 XSP, it's dual rated for Diesel and Gas. If 10W40 has been working for you, why change to 5W40? What climate are you running this car in?
