Sometimes, when it does is not much.Does your vehicle consume oil, are you low when you do an oil change? If not I don’t think there is much to worry about.
Yes, In EU we have use it in Japanese cars and still using it. Even my Honda cars have recommended them in owners manual(acea a3).Has anyone one used European formula oil in a non European car? Ex. in a Toyota etc.. is it ok to use the Euro formula oil in NON European cars?
Im in Plano, and use Castrol edge 5W40 euro in my Optima 2.0 turbo gdi no issues at all.I’m in North Texas during school year and in the Dallas area during summers, we have cold winters and pretty hot summers. I wanted to go back to a 5w but stay with 40, I feel like a 5w40 would be great for my climates.
Relax mate, I had an Audi and like many European cars it consumed oil, yet I ran it on full SAPS oils and everything was fine.Oh no, should I use a different 5w40 brand? Anyone else has an input about it?
owners manual asks for acea a3 in most of the world and gf2 energy conserving only in america, just a CAFE and logistics thing. ford has been a member of acea since its creationThe Jag was designed and built when Ford was running the show at Jaguar so for better or worse it’s not a 100% European product by my way of thinking.
Unless it’s -35F or so then the 0W winter rating isn’t going to make a bit of difference. In fact it may be thicker.Back to the oil, for north Texas, I’d use the 0w-40 Mobil product, not the 5w-40.
moot point there’s no reason to buy Mobil 1 Full Synthetic 5w40 over the proven flagship fs 0w40I’m confused, I lived in Houston for a while, prior to that Buffalo NY. Can’t recall north Texas being that north. You can run 5 down to -35c. Record coldest temp in Texas history was -30°C. If it gets that cold in Texas you’re likely to have bigger issues than cold start wear.
Ok, don’t disagree I typically use the 0w40 unless I accidentally order the wrong jug. But still the argument that you need some special cold weather oil specs for N Texas is a bit silly.moot point there’s no reason to buy Mobil 1 Full Synthetic 5w40 over the proven flagship fs 0w40
Yes that may be how the chart shows in the manual. But what I posted is how the oil actually behaves.Just going by my Jaguars owners manual, they don’t have a specific oil wt. recommendation.
But rather a scale to use based on the temperature range that car is likely to see in the cars “home” locale. Using that for my guide, 0w-40 is the manufacturer’s recommendation for my temp range in NE Oklahoma.
Z
Which is an issue that also doesn’t really exist unless the winter rating is so inappropriate that the oil cannot be pumped. If the oil can pump then it is pumped, and all oils have sufficient MOFTI’m confused, I lived in Houston for a while, prior to that Buffalo NY. Can’t recall north Texas being that north. You can run 5 down to -35c. Record coldest temp in Texas history was -30°C. If it gets that cold in Texas you’re likely to have bigger issues than cold start wear.
That's almost all I use (when using off the shelf synthetic) in my Hyundai. Euro spec oil is very high quality. Sometimes I use an SP 10w-40 or dual rated 15w40 HDEO if the price is good but now that winter is coming it will probably exclusively get euro 0/5w-40s.Has anyone one used European formula oil in a non European car? Ex. in a Toyota etc.. is it ok to use the Euro formula oil in NON European cars?
Just a question. Then what is the point of having Low SAPS oil and ACEA C rated oils?Relax mate, I had an Audi and like many European cars it consumed oil, yet I ran it on full SAPS oils and everything was fine.
Remember that Euro cars like Audi, VW, MB, BMW have catalytic converters too, yet they survive just fine on these oils.
DPF GPF protection aka ESPJust a question. Then what is the point of having Low SAPS oil and ACEA C rated oils?
Right. GPF is gasoline catalytic converter?DPF GPF protection aka ESP
No, a gpf is like a DPF, but for the fine soot created by GDI engines.Right. GPF is gasoline catalytic converter?
