Euro Spec Oil in GM Vehicle?
MA
About to purchase a new truck with GM's new-ish L3B 2.7L turbo 4-cylinder engine. I've become a fan lately of the MB229.51 and VW50400/50700 specs over GM's Dexos1-Gen3.
GM requires Dexos1-Gen3 5w30 but many of the "Euro" formulas that meet MB229.51 and VW50400/50700 seem to be superior and meet/exceed Dexos1-Gen3.
Anyone run into any problems running the Euro spec oils in a GM engine? Below is a general spec comparison from Lubrizol and a datasheet comparison of various oils I've had my eye on. Amsoil, Redline's and HPL's European oil are looking pretty nice!
GM's own Euro spec is dexos2 (blue logo), which is based on C3. Pennzoil Platinum Euro L at Walmart is dexos2 and is likely the cheapest/easiest to find dexos2/C3 out there.
There is no problem whatsoever! Go C3 oils like Mobil 1 ESP 0/5W30.
if you can find it :sneaky:
MB 229.52 is now a more stringent test against LSPI. C2 is a fuel efficient version of C3 and oil can actually pass both tests at same time.
We only know that Mercedes has a LSPI test for THEIR engines. We don't know whether it's more stringent than the test under API SP (ACEA A7/B7, C6)
Your GM product may develop an unknown European accent, which may be nearly impossible to comprehend. Even some of the English accents can be a challenge...even when you understand the accent, the meanings can be odd, such as "bangers and mash", "knackered", "barmy". Then Italian: "rompere le scatole" and German: "kummerspeck", and French: "ah, la vache!" Proceed with caution. Ciao!
