Euro Oil
Euro oils are about the only good thing associated with Europe, other than the views you can see if you visit it. Any engine that’s not a severe oil burner can use Euro oils safely as long as it also carries your manufacturer’s recommended approvals.
Much Obliged Subie Roo!
API SP is most definitely low-SAPS. A full-SAPS oil would help a heavy oil-burner (quart every 500 miles) dispatch its catalytic converter in short order.
That is only true for 30w and lighter correct? Does not apply to 40w's, Mobil 1 0w-40 being FS and API SP rated for instance.
Sure! Just make sure it meets the manufacturers specs.
I have a friend that uses Euro 5W-40 Mobil 1 in his Corvette. Loves it!
Late, but Thanks!!
Thank you sir!
