Marketing claims that ester is the cleanest 2-stroke oil available while literatures claim that polybutene is actually the cleanest.
Evidence of this claim is that most ester oils appear to “only“ qualify as JASO FC instead of the cleanest JASO FD, clearly showing that ester oil is not as clean as a mineral/polybutene.
I do not challenge the idea that, in general, ester JASO FC oils have better lubricity than JASO FD mineral/polybutene.
The reason I post this is to suggest that ester JASO FC oils (often marketed as racing oil) are rarely the best oil you can buy unless:
- you actually achieve substantial high rpm, or
- you like scrubbing carbon off pistons and combustion chambers, or
- you mix to leaner ratio such as 60:1 to 100:1.
There are always middle ground to rules, Motul 710 Ester and Belray Belray Si-7 are examples of JASO FD oils spiked with ester.
My applications are vintage Yamaha street motorcycles, 70s RD350 and RD400 with Autolube oil injection and I don’t like scrubbing carbon, I use JASO FD oils.
