Elf Tech Team - PAO vs Ester
NJ
quote:
SYNTHETICS IN THE POWERSPORT INDUSTRY: ESTERS vs. PAO “Base stocks” are what constitutes 75 to 80% of a finished engine oil. In 1999, the generally accepted rules for labeling an engine oil “synthetic” blew in pieces. A major marketer forced a court ruling allowing oils that are using “Group III – hydrocracked” base stocks to be labeled “synthetic”. Previously, only engine oils using the following base stocks could be labeled “synthetic”: • Group IV: PAO or Poly-Alpha-Olefine, derived from the Ethylene chemistry • Group V, catch-all category for non-PAO synthetic. Esters are a Group V base stock. For some high-performance applications in the Powersports industry, these cheaper Group III-synthetics were not good enough, and to differentiate their products, many Powersports marketers started to specify that their own synthetics were either “Ester” or “PAO”. What is the difference between Ester and PAO applied to a 4-stroke Powersports engine oil ? First, a few facts: - Esters have a property that makes them prone to marketing abuse: small quantities are easily detected in inexpensive lab testing. For example, 3% of Ester will have virtually no useful effect in a lubricant, but a laboratory still will conclude “contains esters”, therefore “contains synthetics”. This makes it tempting for companies to promote Ester as “the perfect elixir”, then put 3% in all their products even if it provides no benefit for the engine. - The Total group, maker of ELF lubricants, is the 4th largest oil company in the world and manufactures base stocks. Total extracts crude oil, operates many refineries, operates chemical plants, and employs 10,000 people in the US Chemical industry alone. In short, the Total group engineers and manufactures lubricants from A to Z. - Most specialty brands of oil in the Powersports industry are from companies that do not manufacture any base stock, be it mineral, hydrocracked, ester or PAO. The staff of these companies is often mostly dedicated to marketing and sales. Most of the technical development is sub-contracted to Chemical groups such as Total, from which they purchase their base stocks. Now, about the respective merits of Esters and PAO for motorcycle oils, let’s first have a look at their pros and cons from a chemist’s perspective: Qualities found in both PAO and Esters (versus Hydrocracked and Mineral base oils): • High Viscosity Index (oil does not “melt” at high temperature), • Very low pour point (you can start in minus degree weather) Now the differences: PAO Ester Pros - Low polarity: good foaming and air entraining properties - High temperature stability - High polarity (=good lubricity) - Straight chain molecules are biodegradable (true of a limited number of esters) Cons - Low polarity (lower lubricity) - tendency to retract and harden the seals - Poor hydrolytic stability (reacts to water) - Incompatible with acrylate seals, risk of incompatibility with nitrile and VAMAC (depends on the type of ester) Polarity causes the ester molecules to be attracted to positively charged metal surfaces. As a result, the molecules tend to line up on the metal surface creating a film which requires additional energy (load) to Visit: ElfMoto.com 877.ELF.OILS ( 877.353.6457) penetrate. The result is a stronger film which translates into higher lubricity and lower energy consumption in lubricant applications. On the other hand, PAO’s low polarity means that they have better foaming and air entraining properties. Foam and air entrainment occurs when the engine is going at very high speed (which is often the case with a motorcycle). Foam and any bubbles formation in the lubricant is detrimental to the engine. So we can deduct the choices that the formulator has when he makes a 100% synthetic lubricant: 1 100% ester: very unstable, incompatible for most seals. 100% ester lubricants will have to be drained from the engine every few hours. Reserved for applications when their polarity is so necessary than their inconvenience will be dealt with. For two-stroke applications, where the engine oil is mixed with the gas and must burn, the instability of esters is a good thing. It is not the case for four-stroke applications. 2 Mix PAO-Ester, with balanced proportions: probably the best combination for Car racing engines. Three drawbacks for motorcycles: a. Motorcycles with a wet-clutch: Esters’ polarity will act on the clutch much like Friction Modifiers do. They’ll make the clutch slip. A lubricant with strong Ester content is unlikely to pass the Japanese JASO MA test to prevent clutch slippage. b. Motorcycle 4-stroke oils are often used off-road where the environment is not as controlled as on the race track: you may have to cross a river at low speed, and your Ester oil may not like the water… c. The attraction of the oil to the metal is no longer needed at high speed, when hydrodynamic lubrication is protecting the metal (the equivalent of “aquaplaning” in your engine). On the contrary, the attraction of the Ester molecule to the metal will slow that “hydrodynamic” phenomenon and may cost horsepower. At high speed, the resistance to high temperature and to foaming that PAO provides is more important than the low-speed lubricity provided by some esters. 3 100% PAO, with or without a few drops of Ester. Esters are sometimes used in small quantities as a seal-softening agent, to counter seal-hardening. They can also be used as a “marketing boosting” additive (see earlier note on its detection by lab test), in which case, the label proudly claims “Ester synthetic” but also “JASO MA”. Overall PAO will have a better high temperature stability and oxidation resistance than most esters. This is most important for motorcycle-specific lubricants since motorcycle engines will be working under higher revolutions and overall at higher temperatures than car engines. ELF Moto 4XT 10W50 and ELF Sport Campione 10W60 are 100% PAO, with the proper additivation to prevent seal hardening, and performance on the clutch that allows to pass the JASO MA test. On the other hand, ELF chose 100% Ester base stocks for its 100% synthetic two-stroke oils. In the ELF 4XT 10W50 and ELF Campione 10W60, Total engineers put all the experience of the group to make these the best 4-stroke motorcycle oils on the market by their combination of: - viscosity range: notice the large viscosity range 10W50 and 10W60 for a 100% PAO synthetic with extreme temperature resistance. Most European dirt bikes now, - Clutch compatibility (the only 100% PAO oil to meet JASO MA with a 10W50 viscosity !!) - Capacity to yield horsepower: no metal attraction will slow the motion of parts. The ELF Moto technical team.
australia
well don't tell my hd about clutch slip been using motul 15w50 300V in primary since day 1 65,000 miles to date NO CLUTCH SLIP
Kyiv, Ukraine
Buster, Thanks for an interesting article. However, as usual. May be the time to start calling you Buster the Digger ? [Cheers!] As for the content, after reading the comment "100% ester: very unstable, incompatible for most seals. 100% ester lubricants will have to be drained from the engine every few hours" I am burning of desire to go to my Honda and drain 300V 5W-40 despite the time. Please, don't post such horrors, somewhere it may be already night.
buster
NJ
Primus, I don't know where they get off saying this when Redline, Motul, Maxima and Molekule have said otherwise. While they don't contain 100% Esters, they contain a majority of esters (multiple) and some small % of PAO. I'm very surprised this was written as such. Their seems to be two schools of thought out there about majority ester based lubricants. As Molekule has stated before, you can get excellent performance by adding less ester to PAO, which is a less expensive solution.
buster
NJ
Huh? I thought it was the opposite. [Freak]
FL
yeah exactly Buster if this is the case why do turbine jet engines use esters? at least that is what i thought redline claimed.
Dixie
Buster, You keep missing the boat on this one.... Both PAOs and diesters/polyolesters have advantages and disadvantages as an engine lubricant. By blending them you get a better overall mixture of physical/chemical properties than you can with either basestock alone. Got it? [Smile] TS
Retired | Wausau, WI
I had to read through that a few times just to be sure this was from their tech team. Lot's of technical information in there for sure, but it's also full of marketing. After spending 25 years in the oil industry I've heard the same thing from Exxon/Mobil, Shell (Pennzoil/Quaker State), Chevron/Texaco, ConocoPhillips (Kendall/Union 76), and Valvoline. All of which make the complete package from ground to your car. Plus the hundreds to thousands that buy base stocks from these and blend their own brands. And a few of these smaller blenders (two come to mind, Amsoil and Red Line) will certainly give Total a run for their money. So, as technical as that may have been, it was a good marketing sales pitch.
TX
Aren't the "high" ester oils like Redline, Motul, Cosworth, and Synergyn only about 20 - 40% ester?
Consider this, the most popular PCMO on this board consists of a PAO base with PAO derived ester add pack... How'd they do dat........ What would the frogchemists say bout that? Yikes I'll be in Paris soon, duck! Yup ...pscholtes'GC green and its a good racing oil too..
buster
NJ
I'm well aware that it's marketing and I'm well aware that their are blends of PAO/Esters. However, some oils are mostly ester and some are mostly PAO. The article makes reference to seal compatibility issues with esters. (Not true anymore) and that PAO's have better oxidation and high temp. qualities. (that I thought wasn't true). Ted, got it?
Everson WA - Pacific NW USA
I think that article is extremely poorly written. But I have come to learn to not hold that against buster. The pros and cons part is especially pathetic. Was it a direct translation from the French?
Kyiv, Ukraine
From Motul Web page: Question: - Do Esters in oils swell seals or is this just a rumour. Safe for motors, gearboxes etc,? Answer: - Yes you are correct they do swell seals. But nobody makes a full ester oil anyway. It is usually mixed with other base stocks i.e. PAO (Group 4) or Hydrocracked (Group 5) which reduces seal swell. Ester are very expensive and really anything more than 25% really provides little advantage. Interesting what they would say about biodegradable oils. Given requirements for biodegrability these oils should be nearly 100 % esters. [ July 18, 2006, 11:24 AM: Message edited by: Primus ]
Southern California
There was NO court ruling regarding Castrol's obtaining permission to claim Group III base oils as "synthetic". The matter was decided through binding arbitration mutually agreed to beforehand by Mobil and Castrol and conducted by the National Advertising Division of the Better Business Bureau. None of this invalidates ELF's oil technology, but if they can't get a basic historical point right, it can't help but call into question the rest of their points, too. Somebody at ELF needs to be reprimanded for reckless seat-of-the-pants literary creativity.
buster
NJ
Ester Link Maxima has a great tech staff that will really go in depth with you on this subject. Their oils are majority Ester based. They don't have to compete with oils on the shelf, so they use various esters in their oils. The Elf marketing PDF I posted was a bit inaccurate IMO. First, you can make a 100% ester based oil by using a certain type of ester. Maxima uses up to 80% Ester for their engine oils. In fact, they use several esters per oil. Ester based oils are clearly overkill, but for those that do want the best for hard driven vehicles, it does appear that esters are the way to go.
