You have an air flow problem. Originally, when these cars came from the factory with a 6-cyl engine (the majority of them did), the radiator was mounted in front of the core support, and on the factory V/8s the radiator was mounted behind the core support. If the radiator is mounted in front, move it behind. Then you need to install a shroud. Additionally, if the fan is too far away from the radiator and the shroud doesn't cover at least part of the fan, you need to install a thicker fan spacer. Aim for about 1" spacing from the radiator. I had a 56 that did the same thing, installing a shroud and thicker fan spacer solved the problem for me.
