3.0L Duramax cold start warmup graphs
wwillson
Staff member
Colorado
I started my Tahoe up in the garage at 46F and drove about 15 miles on a county blacktop to the interstate in 20F ambient temperatures. The graph ends about 3 minutes after I got on the interstate. The Tahoe has louvers over the radiator that stay closed until the engine coolant temperature is > 180°F. The closed radiator louvers help the engine coolant warm up faster and prevents the charge air cooler radiator from being cooled. The engine coolant and charge air coolant are two completely separate systems. Warmer charge air also help the engine warm faster. There is a thermostat in the charge air coolant loop that maintains the charge air temperature at about 90F. When everything is up to temperature the charge air will stay around 90°F even when the ambient temps are well below zero. When ambient temperatures are at or above 75°F the charge air cooler system doesn't have enough capacity to keep the charge air at 90°F and the charge air temp will creep up. The highest charge air temperature I've seen is around 140°F when the ambient temp was +95°F. Keep in mind that the compressed air temperature post turbo is highly correlated to intake air temperature. If the intake air is 0°F the high boost post turbo temperature will be around 250°F. If the intake air is 100°F the high boost post turbo temperature will be around 350°F.
Interesting. My 23 GMC AT4 3.0 didn't come with louvers. In the summer do they still open & close in say 80 degree weather?
Yes, when the vehicle is shut off, they close and do not reopen until the engine coolant temp reaches 180°
I would be shocked if yours didn’t have louvers. Look up behind the front bumper from ground level.
My Ecodiesel has these "active grill shutters" as well, to help with cold temps and faster engine warm up. On a cold start, these diesels also rely on EGR to hasten the warm up process.
The active shutters are cool and all, but it is yet another potential failure point.
They put them on just about everything now. My 2015 has them and they also stay closed in the winter however there is a space on top of them always open.
