If you just look at the numbers between 1k and 12k you will get a better idea of the wear.quote:
Originally posted by Ugly3:
]The problem I have is that I have not seen any data that suggests the wear metals in a used oil analysis relate in any way to actual engine wear. Look at the Paradise Garage study, there is virtually no wear reported in the 1000 mile used oil analysis from 5,000 miles to 15,000 miles. I don't think that can be so I think there must be some anomoly going on.![]()
I noticed that comparing the Amsoil 3.5HTHS to the Mobil 1 3.08HTHS wear numbers it shows that over the 11k period between 1k and 12k the Amsoil has about 1/2 to 1/3 the wear on the iron/lead/copper/aluminum.
I wonder if this difference is due to the HTHS difference?
