quote:
Originally posted by buster:
I don't have the knowledge that most of you have with cars and engines, but at this point my opinion is that viscosity plays little role in wear. I think oils today are far superior then the past and that you can run 20wt oils with no problems. The chemistry is better and additives which are what makes an oil great. Starting with 30wt makes perfect sense but doesn't mean you can't use a 20wt. or even a 40wt. in certain engines. We see good and bad reports in ALL different viscosities. Mobil even states on there website that SAE viscosity alone doesn't tell how well an oil can protect. It's the quality of its' components that makes it good.
I don't believe this is true Buster, especially that vis. has little to do with wear. If this was the case, why does Honda feel the need to add 400+ ppm of moly on their 20wt oil. They are compensating for the thinner oil and maybe even hoping for the best. I'm gonna jump on JBs band wagon on this issue. Here is my un-educated theory:
-I believe for low HP, low RPMs engines like a Corolla, Civic, Accord, etc; which is NOT MEANT for racing or the like, a thick 5W-20, middle to low 5W-30 oil will do. This would have to be a quality oil like M1, AMS and even Honda's oil.
-For all other small to medium displacement motors that rev high and/or have more HP, then a 5W-30/10W-30 oil should be enough.
For all other applications such as P/U trucks, sports cars, RVing, towing, etc, etc, then, I believe you will benefit from a middle 10W-30 weight on up; to include 40/50 wt. 5W-30/0W-30/40 would be ok for the winter.
I don't see myself towing 5000 lbs of cargo in a Ford truck that the manufacturer recommends a 20wt oil. I'm not that brave.
Rick
