I don't have the knowledge that most of you have with cars and engines, but at this point my opinion is that viscosity plays little role in wear. I think oils today are far superior then the past and that you can run 20wt oils with no problems. The chemistry is better and additives which are what makes an oil great. Starting with 30wt makes perfect sense but doesn't mean you can't use a 20wt. or even a 40wt. in certain engines. We see good and bad reports in ALL different viscosities. Mobil even states on there website that SAE viscosity alone doesn't tell how well an oil can protect. It's the quality of its' components that makes it good.
