Engine assembly pre-lube
Michigan
I've always used an ample quantity of pre-lube for the bearings, cam lobes, seals, bores (no moly here), rings, etc, etc. But other than not using moly on the rings/bores/pistons, I'd just buy "stuff" called pre-lube (or, mix STP with regular oil, 50/50) and pour it on. So here's my questionS: 1. What is in this pre-lube??? And 2. Though most of it that I see is red in color, some I've seen is white. What is this white stuff? Thanks to any that can shed some light on this for me.
MolaKule
Staff member
Iowegia - USA
I can't vouch for other pre-lubes, but our synthetic pre-lubes have concentrated amounts of EP and AW additives, with a bit of tackifier to make the lube stay on the part. Our pre-lubes will flow in really cold weather as well.
