Following. The cleanliness is breathtaking.
I did the job this week. I pulled the cam, and since I couldn’t find a bad one, I threw all the lifters I had. Unfortunately I only had nine, not 10. It was easy to pull the cam.
For completeness I’ll post some photos here.
Lined up cam at TDC. 2.5 degrees of wear. FSM says that wear should be 2 degrees after 20k miles of break in. So essentially perfect.
Tie up the chain to the gear so it can’t jump teeth. Bolt removed.
Removed the cam. Specific de-torquing procedure to prevent damage.
Use a small magnet to remove lifters. My two oldest kids helped with all this.
Slathered things up with assembly lube and put the bearings back on in the right order. The cam sprocket bolt was the hardest thing. 45nm then 90 degrees. Beyond a point I couldn’t prevent the engine from being turned by the cam bolt. Eventually I was able to find something to wedge in to stop the turn. It worked out. No broken cam. Fired right up.
Alas, in the end, it wasn’t lifters at all. They checked out on because they were ok.
It was an injector that had been refurbished and balanced. And was hard to correlate the tapping and knocking via stethoscope… but that’s what it was.
So in the end I’ll find a good used injector, get it pop tested, and then put it into use. I don’t know if the old noisy injector is salvageable.
