Originally Posted By: Jim Allen
It all boils down to as thin as possible as thick as necessary, doesn't it?
In some places and with some vehicles, meeting that basic requirement might be a XW40 or XXW40. In other places and with other vehicles, it might be a XW20. I think it's a mistake to assume that one end of that scale is automatically better than another without considering all the individual factors. These would include the engine, the operational conditions, climate and the particular oil being used.
In truth, most engines will operate well, or well-enough, within a broad range of viscosities. That's the saving grace for all those standing on either of the thick or thin soapboxes. You really have to go radically outside the box to reach a sub-optimal condition where bad results are immediately noticeable. That optimal viscosity point is still there for every engine, but it's dancing around depending on the individual conditions.
What's the optimal viscosity point? IMO, it the point at which efficiency and protection converge for a particular engine in its operational situation.
We can take a lot of clues from the OEM recommendations, no matter which part of the world they come, if we look at the prevailing conditions in that region. But "clues" aren't always gospel at either end of the scale and saying one is universally better than another is silly.
A lot of testing has been done, is being done, to validate the thinner oils. From what I've seen, more testing has been done in that direction than to prove heavier oils are "better." That's probably as it should be, since thick oils are the "no brainer" choice. If you don't care about efficiency, that's a safe direction. Going thinner requires more care and better oils.
I agree with everything you're saying, however here's an example that throws a monkey wrench into the works. My 08 Liberty only calls for 5W20 oil, no other options. In other parts of the world with similar climates to the USA they have other options for the same identical engine. In the US if I fail to use 5W20 and decide to try 0W30 I could very well have a warranty problem should something go wrong. If I move to OZ I can select the grade of oil based on how the vehicle will be use and the climate, and maintain a warranty if I bought the vehicle there.
