No where in my post did i say they weren't interested in engine longevity. did you read my post thoroughly? i stated that perhaps the cost to performance ratio is not beneficial for Amsoil, and many others for that matter. As you stated, their oils protect well according to used oil analysis so why change? the job is getting done very well right now. And i never said a cheaper oil would perform better. i was asking what is the true benefit in engine protection over the period of time when using a oil with a VI 0f 220 vs and oil with a VI of 150, and gave mileage as and example/question.
Also add to the price of a quart of SS and your well above 10$ the more expensive they have to make the product the harder it is to move the product.
I just put a spin on what you said, which btw was good. I was trying to bring up a point or two, I wasn't calling you out. IMO just because an oil has a high VI doesn't necessarily mean it is superior, or Amsoil and Red Line would have hopped on board. Amsoil 0W20 is thicker than most 0W20 oils, as is Red Line's, they must have a reason, or maybe they really are behind the times.
its hard to see the spin on things over typing, i apologize if my response was rude. as to your question, my guess would be as long as a lube continues to provide low wear in and engine, it is worth using. so regardless of VI, oil needs to provide protection. I agree High VI are better, but at the same time i believe a case has to be made for lower VI oils as they have put many a engine well past 200k. So i suppose that maybe Amsoil, and redline are playing midfield so to speak. they are putting products right in the middle for VI. not super low, but not super high, and it seems to be working well. from looking at their oils however, it appears that both amsoil and redline prefer their oils on the "thick" side. on the other hand companies like Sopus tend to run a little thin. the cool part is both the thick and the thin oils are providing great protection and low wear. that is making me think that maybe it does not matter. here we are confused even more haha.
Yes typing to communicate can leave a lot to the imagination. We seem to be thinking along the same lines. There are people taking the stance that thin is in [I was one of them], and that the higher the VI the better the oil. From my reading, thin is in and higher VI doesn't add up to much, if anything at all. So getting hung up on it, or fighting about it here is really meaningless. It is fun, and does make for some interesting reading though. JMO
Trav mentioned something in one of these threads, it might even be this one. There are about three nations in the world hung up on thin oils, and over 190 nations using the exact same engines running thicker oil. Is there a conspiracy to have those engines in the 190+ nations running thicker oil with less VI to self destruct? Is there a conspiracy to have those people burn more fuel with the thicker oil? As of yet I have not seen a reply to Trav's statement that was compelling enough to believe. I wish I knew the real reason, not just educated guesses.
