Had an electrician install a subpanel now I want to DIY the wiring for a new mini split I am doing.
I ran the wire behind the drywall and fed it through but what are my options to hold the wire going into the box?
It’s against the drywall if that makes sense so to make this work do I really need to remove the entire subpanel from the wall to get a NM romex clamp in to meet code?
Thanks,
Thanks,
