This is a great thread, and love how its getting down to the nitty gritty (tech term).
I have a question if I may. At the moment I am running 10W-40 full synthetic high ZDDP oil (Penrite 10tenths racing). After a hard run oil temps get to around 100degC (which isnt that high I know) and pressure drops from around 300kpa/44psi(warm) to about 200kpa/30psi (hot) at idle (1000rpm). Sometimes it drops a bit under 200kpa if I come straight off the track and let it idle and just sets off the low pressure 20psi warning light. It quickly restores after a cool down, and I have an oil cooler and on the cool down lap it drops quite a bit, so cooling is working. Ambient temps during cold months range 5degC - 20degC
Anyway, for the hotter summer months I am thinking using a heavier 15W-50. What do you think ?
The engine is a 347 stroker windsor roller cam with 0.0025" clearances (I think) and HV oil pump.
When cold at first start up it sits around 350kpa/50psi, when warmed its sits around 300kpa/44psi, and then of course hot after a run can drop to about 200kpa/30psi as stated. This is all at idle @1000rpm. Of course press goes up as rpm increase.
50psi at idle is still decent oil pressure, and the oil temp quickly recovers on cool down lap, so I don't think I have a problem or anything, its more extra protection during the hot summer months. My only concern is going to heavy, but I guess when it reaches higher op temps it wont matter.
I have read going to heavy is just as bad as going to light an oil. My understanding is:
Too High vis = poor cold start lube, increased drag, higher oil temps, loss of power.
Too Low vis = less high temp protection, durability and life. Lower oil pressure.
The type of racing I do is not sustained high rpm, its short speed events - 4 hard laps at a time, similar to qualifying laps I guess.
Thanks for any advice and guidance.
