Originally Posted By: Shannow
Originally Posted By: ZeeOSix
In actual use at full operating temp (100 deg C), the difference in pump slip between running say a xW-20 vs a xW-30 or xW-40 in an IC engine isn't going to be enough to cause any oil flow/delivery issues. The delta in viscosity between those oils when fully hot isn't that drastic. Most pumps are over designed anyway, so any small increase in slip isn't going to make any difference impacting proper lubrication.
Exactly my point all along...
Pump only ever has to supply enough volume for the bearing's make-up requirements at the worst point, and operating point of the engine...the excess delivery is seen as "oil pressure".
Oil pressure may well be necessary when having to cool pistons, run actuators and the like...well at least that's per Honda's papers for street engines say as they reduce viscosity.
And along with that, the excess PD pump volume is also causing increased flow through the now "pressure fed" journal bearings due to the increased oil supply pressure. Journal bearings will also contribute to the overall flow resistance of the oiling system due to their tight clearance in conjunction with the PD pump trying to force more oil through the bearings than they would "naturally draw" while rotating. Basically saying he same thing, but with the pressure fed/more flow caveat. Definitely need oil pressure for such things as cooling jets, chain tensioners, variable cam timing actuators/phasers, etc.
