Originally Posted By: userfriendly
I couldn't help notice that the flow rate @ 7500 rpm didn't change much with incremental grade changes to thinner engine oil.
I would assume then, that oil pressure from one grade to the next, would not change at all.
If I throw this discussion back to oil pressure vs viscosity, vs oil pump capacity and relief pressure setting, very little would change at high rpm with viscosity changes.
My take; The pump then, if properly sized for the engine regardless of viscosity, should be operating at relief pressure at high rpm.
The oil pumps move a [chunk] of oil so no matter the viscosity of the chunk the chunk will be the same size. pressure is the resitance to flow and thinner oil leaks out of the bearings faster.
