Easiest way to attack upper shock nuts?
The top if the stud is a double "D". Grab that area with locking pliers and use the wrench of your choice on the nut. I think a flare nut wrench can fit thru the stud. It's slow going but effective. Or find one of these shock tools (I haven't seen these in a long while).
I was hoping to get something similar at the orange or green boxes. Nope. Special order.
I'm confused....vise grips and a ratcheting wrench or pass-thru socket is all I've ever used? This need not be rocket science??
If the above doesn't work I slash and burn with abrasive cut off wheels or PFM (pure F'n magic aka plasma)
I put Vise-Grips and a 15mm box end wrench to the test. Didn’t budge. Broke out the M18 Fuel Sawzall with an Diablo Steel Demon blade.
