Early failure of Amazon Basics AA alkaline battery
SE British Columbia, Canada
I had another failure of a Amazon Basics Alkaline AA battery. My flashlight has 6 batteries, inserted from a fresh package. The flashlight eventually went dim and rather than chucking all six batteries, I checked all the voltages. One battery was down to 0.1 V. The others were about 1.3 V. I replaced the bad one and got bright light again. Glad I checked.
I’m finding Amazon Basics has problems like this once in awhile.
As a tech I was a D cell power user for years. All the brands have that issue, out of the blue one seems to have an internal connection issue. Energizers were more problematic for me. Had it with ProCell's from Grainger also, Co. supplied. I'm a Duracell person now, it happens with them but less frequent. Have run into it with Energizer Lithium's also.
I haven’t bought alkalines in a decade at least. Lithiums or rechargeables. I got sick of cleaning my things from leaked batteries.
Sometimes that's what you get for 25-30¢
Have used them and they seem pretty similar. Myself I have not had a Amazon not charged or a leaker. At one time I used Diehard from AAP
IN the alarm industry we have had so many issues with the major brands leaking in some sensors. It seems like once they start getting run down, even though the sensor would still work (and would not trigger a low battery signal) for some reason they were terrible when in a low charge state for a long period of time and would leak.
Even at home in my LED flashlights I had issues. So it was never more for the major brands and here these over 50% less costly.
I am almost to the point where I use something with a battery and when done, pull the battery and put them in a baggie next to what requires the battery.
Probably not a flashlight but other things that require a battery.
I bought a ground loop meter for HOA to check a ground loop for the gate. Cheaper than one call to the gate company. But how often will it be used?
The bulk packs of Duracell and Kirkland-branded alkaleak cells at Costco offer the best value.
But having had one too many leak in devices, and recently discarded new, unused cells for the same issue, will pursue other options.
