Quote:
What is A3 ? and does Castrol Gtx meet those standards? Does A3 certified mean it's like a world of difference from GF-4? thanks
ACEA Ratings
http://www.infineum.com/information/consumer.html
Quote:
I call bunk on regular Valv 10w-40 meeting A3.
Quote:
Durablend has also produced some good looking used oil analysis as well.
Quote:
Reading this bottle of DB. SM,CF, A3. No GL-4 on the bottle. so the conventional 10w40 said GL-4 but no A3, now the DB says A3 and no Gl-4. Do they clash with each other or somin?
Quote:
What is A3 ?
A European standard of long drain oil with an HTHS greater than 3.5, over kill.
Quote:
Quote:
What is A3 ?
Thanks for that information. I did not know this before. I will be certain to avoid this A3 qualified oil at all costs due to the high HT/HS requirements. I though this requirement died in the late 1990's when the Europeans learned a little more about oils.
Quote:
SM and A3 together is quite a feat. SM limits additive levels, A3 needs a healthy add and basestock combo.
Quote:
Worse than that. In a 5w20 grade you need a HT/HS near 2.6 to qualify on the fuel mileage qual. You are toast trying to do that at 3.5. European spec designed in the stonehenge age.
