Ducati 821 Filter
UncleDave
$100 Site Donor 2026
Ca.
Buddy got a new to him bike and we pulled a filter and too a look.
Interesting and impressive construction, the ADBV was wafer thin and the top of the element had a spring loaded plate. I didn't capture this plate well, but still have the can if anyones interested.
Seam appeared sewed and well executed. Nice thick can and baseplate.
The media appears to be paper/glass and the wavy construction is executed well and the media is solid but then it only had about 3500 miles on the filter.
The core has holes not louvers.
The unit had a very robust spring loaded bypass on top.
On a separate note he was talking smack about blowing me into the weeds on my 2 decade old " old man" stallion.
No doubt I couldn't keep up with him in the twisties, nor do I really even try hard anymore.
When the road open up to high speed long uphill sweepers this whippper snapper got schooled.
Despite having nearly the same HP on paper and him with a bunch of upgrades like an annoying loud pipe and electronic whiz bangery, the Italian laser guided, plasma cooled, vertically loaded, techno tour deforce got its rear end handed to it by this old school analog carbureted, air cooled, slide rule designed, bone stock Suzuki - and not just a little bit either - convincingly. The ride was huge fun.
View attachment 238566View attachment 238567View attachment 238568View attachment 238569View attachment 238570View attachment 238571View attachment 238572View attachment 238573View attachment 238574View attachment 238575
Very nice, media or filter appears PurFlux made. What filter did you guys put back on? Oil change too? Thank You good sir 👍🇺🇸
Purflux is a pretty huge filter manufacturer, supply a lot of OE Euro filters to the big boys.
Here is a Ferrari 458 oil filter
Thanks, I haven't owned many euro vehicles and I grew up on American and Japanese iron.
From a 'will it fail' standpoint I'd be really comfy with one of these on a car for a long period.
I dont know how well it actually filters though - do you know the specs on these?
Appears to be a Purflux design. Purflux was, until very recently, owned by SOGEFI who also offered Coopers/FIAAM filters and FRAM in Europe as well as many other lines of business. Appears that the SOGEFI filtration business was sold to a PE as the Purflux group, interesting. Every SOGEFI filter I ever used and dissected was top notch, hope that continues. IIRC SOGEFI also makes the oil filter module on the Wifes Jeep JL.
Depends what your definition of Top Notch is I guess, they're not a brand I'd use.
And what would you use?
Purflux is good enough for Ferrari, MB Ducati as noted here as well as VW, various Stellantis brands and Coopers/FIAAM and Tecnocar are pretty well respected in the Euro aftermarket...
Coopers/FIAAM LR Defender 90
After seeing the obviously poor standard of filtration provided by a Coopers air filter I recently replaced on a car I've just bought I won't be buying anything made by Sogefi myself. There's loads of better products available, often for less money too.
Please share details. Curious as their oil filters, at least those I used on my Rover appear well made.
That doesn't mean they filter well.
I thought this test was excellent, I now use either Alco or Hengst.
Thanks and this is an interesting bit of information. The Purflux and sister Fram filters appear rather poor, certainly as compared to some of the others. Fram is lower end overall in the US fyi.
Also interesting that the reviewer noted that the SOGEFI oil filters he experienced were of good quality, mirroring my experience. I wonder if the air filters are recent production and reflect a decline in quality resulting from the spin off of the filter business and any cost rationalization. Hope not, but I will look closely at my next coopers/FIAAM oil filters.
Hengst get is one of my go-to’s as was Mahle, until their China move, although quality still appears fine as you’d expect. That said, given the state of the aftermarket, I am starting to purchase more and more of service goods as OE from the dealers or trusted parts houses. More costly? Yes, but immaterial in the long run and better chance of good quality.
It's a real minefield, I've just had to change four barely worn brake pads today, again many of the Once Greats are just producing xxxt that just binds and gives poor performance. It's OEM, ATE or Textar for me.
Mahle make a good cabin filter and oil filter, I don't mind the fact they're made in China, I've seen a poor Bxxxh opened up that was made in France. It's a real minefield, you have to research everything now so carefully, and watch out for fakes.
