Coopers-FIAAM FT5916
New England, USA
New one here. One of the LR parts suppliers I use carries these filters. Coopers-FIAAM is a SOGEFI brand as is Purflux and several others including Fram:eek: in Europe. SOGEFI is an OEM and, as I noticed yesterday on the Wife's Wrangler, they supply the oil filter assembly for the Jeep 3.6.
Very nice filter with a very heavy can; harder to cut then the Mahle's I usually use. The relief valve is a rubber button at the end cap, but the ADBV is interesting. The ADBV is a sprung collar (see 2nd pic) with a very, very thin and pliable gasket bearing against an almost flat and very thick base plate. COO Italy.
Coopers-FIAAM is now on my 'approved' list.
This is from our French spec Land Rover diesel, hence the inky black Mobil 1 Turbo Diesel Truck.
Very nice photos. I’m guessing same filter and Mobil 1 Turbo Diesel Truck went back in and on correct? Thank You
