Does it? I've only seen it once in 40 years of driving all over the USA.Happens all the time.
The one time I saw this was just a few months ago. A fellow walked into the convenience store with the fuel pump running, when he came out he got in his van and started the engine. I ran over yelling and waving my arms and saved a guy from the consequences of his own stupidity.... I've only seen it a handful of times, but oddly enough, only one person was paying enough attention (or brave enough, I suppose) to stop and tell someone.
Yep. Worked at a gas station for a summer in high school years ago. It happened a lot more often than I would've expected.Does it? I've only seen it once in 40 years of driving all over the USA.
Good luck with that $5 sticker being enforced. They can ask however collecting is another matter thru civil courts.
I'd be surprised if the driver's insurance didn't pay without going to court. Especially if the incident is caught on video.Good luck with that $5 sticker being enforced. They can ask however collecting is another matter thru civil courts.
I watched it happen, the nozzle seems to break off with out any damage to car.With cameras at most gas stations it might be a lot easier. But doesn't it also damage the vehicle?
Which is why I avoid buying gas in that state, if at all possible. I’m there often, and it turns a five minute gas stop into something much longer, and more inconvenient.No wonder some states require an employee pump the fuel. New Jersey being one of them.
All the pumps around here have the break away fitting on them.
2306.7.5.1 Breakaway devices.
Dispenser hoses shall be equipped with a listed emergency breakaway device designed to retain liquid on both sides of a breakaway point. Such devices shall be installed and maintained in accordance with the manufacturer’s instructions. Where hoses are attached to hose-retrieving mechanisms, the emergency breakaway device shall be located between the hose nozzle and the point of attachment of the hose-retrieval mechanism to the hose.
2306.7.4 Dispenser Emergency Valve
An approved automatic emergency shutoff valve designed to close in the event of a fire or impact shall be properly installed in the liquid supply line at the base of each dispenser supplied by a remote pump. The valve shall be installed so that the shear groove is flush with or within 1/2 inch (12.7 mm) of the top of the concrete dispenser island and there is clearance provided for maintenance purposes around the valve body and operating parts. The valve shall be installed at the liquid supply line inlet of each overhead-type dispenser. Where installed, a vapor return line located inside the dispenser housing shall have a shear section or approved flexible connector for the liquid supply line emergency shutoff valve to function. Emergency shutoff valves shall be installed and maintained in accordance with the manufacturer's instructions, tested at the time of initial installation and tested at least yearly thereafter in accordance with FC2305.2.2.
Neighbor down the street drove through the back of their garage a few weeks back. See they found a contractor to repair the framing and lay the brick. It happens.I’ve done this before admittedly. I was on my way home from working long hours. It was late and I was exhausted. I didn’t damaged anything though.
Some name calling going for this. Not really sure why. We are all human and make mistakes. Some people are quick to be judgmental of others. I guess those people must be perfect and completely beyond reproach. Probably never made a mistake in their life, right?
If I'm not mistaken, only 2 out of the 50 states require it. Pretty sure it's not for "safety" either.No wonder some states require an employee pump the fuel.
Never in my life have a I seen it happen or the aftermath. I've seen pictures on social media, sure, but that doesn't mean it's common.Happens all the time.
Some definitely act like they're perfect, they raised absolute perfect children, and so on....Some people are quick to be judgmental of others. I guess those people must be perfect and completely beyond reproach. Probably never made a mistake in their life, right?
I have a career where mistakes like that can result in disaster. For me and all those for whom I am responsible.I’ve done this before admittedly. I was on my way home from working long hours. It was late and I was exhausted. I didn’t damaged anything though.
