So this is on my girlfriend's 2001 Mustang (V6). Late last year, it developed bad hesitation under acceleration and a shaky idle. Initially was told it was the fuel pump & catalytic converter restriction which were replaced but the symptoms remained. The spark plugs & wires were then replaced and the symptoms disappeared. It drove perfectly fine the way it did except the MPG dropped a good 20% or so. It never got good MPGs anyways but it's now at about 15 MPGs down from about 20 MPGs. Here is my checklist that I've gone through that have been replaced recently:
- Spark plugs
- Plug Wires
- All four catalytic converters
- Air filter
- Fuel filter
- Fuel pump
- Brand new tires, inflated properly (didn't effect MPGs with old tires to new)
- ATF fluid was done a little over a year ago along with the filter.
With 150k on it, the only thing I didn't find in the paperwork was O2 sensors. There are no CELs and no smell of fuel. Other than replacing the O2 sensors, where else should I look?
- Spark plugs
- Plug Wires
- Air filter
- Fuel filter
- Fuel pump
