Drain pan plug washer/gasket
Anyone use the clear nylon ones over the oe coated steel ones? Any real difference anything to watch out for?
Unless it's my only option, I never use those. For 14mm size threads, I use aluminum crush washers and for 12mm, I use the Toyota coated ones. Where the original had a captured rubber seal under the head, that's what I use. All other situations, I use the steel washer style with the rubber seal inside.
the only ones I head leak were the blue nylon ones.
The fiber covered metal crush washers never had a problem with those.
The blue ribbed ones look like a possible leak. I would think oe torque specs need to be lower if using nylon in place of steel?
I got some fiber ones off ebay that would compress over time and mileage. Drain plug torque was shockingly loose after 1000 miles. Never again.
