Originally Posted By: m37charlie
Is this a kit one can buy?
Hopefully, they will come out with a similar setup for AdBlu equipped vehicles when Euro 6 comes into effect in 1-2 years, then it will be the same system as we have now in the US.
EGR may make the car warm up faster but the soot that goes back into the cylinder causes a lot of wear, puts soot into the oil much faster; and I think a good tuner could improve economy with EGR blocked. Extra cool fresh air is very good for complete diesel combustion; EGR actually increases soot production which is why the DPF is needed with the EGR in place.
And beware: on the X5 I've had the EGR cooler fail, replaced under warranty with an "improved" part. It is subject to tremendous thermal stress.
Charlie
Hi, this is the company that does the DPF removal pipes and software
http://www.ecotune-scotland.co.uk/
Another quick question if I may, would a standard BMW LL01 legacy oil as you put it protect the engine any better than a regulary changed low saps oil??, the reason I ask is I do have 10L of Mobil 1 ESP 5w30 at home, I only got it the other day so could take it back for something else, the motor factors that supplied it also does BMW LL01 Valvoline, how do you rate there 5w30 synpower or synpower mxl??, or can't you get that oil where you are??
