Bruce
Actually, I do know quite a bit more about the oil than has been revealed by Terry on BITOG, and my statement that you are about 25% accurate in your assumptions stands.
As for extended drains. We're currently running 5K drains on the BioSyn oil in my engine, which is probably one of the harshest environments around, and included 2 1/2 hours at full power on the track at Lime Rock. (The RS4 V8 produces 420 HP at 7800 rpm, with a 8250 rpm redline. Oil temperatures in normal driving typically run 220F, with track oil temperature running about 260F. I am not gentle with my engine, which Terry can attest to.) Oxidation, Nitration, and soot analysis numbers are extremely low. Normal (non-track) operation should give us at least a 7K OCI. I would have run longer, but we have a tweaked formulation that Terry wanted me to try that he believes may be good for close to a 10K OCI.
For a point of reference, Audi 502.00 approved oils, when operating in this engine, have a life of about 3K miles before the oil has diluted and sheered to the point that it is dangerous, with incremental wear numbers that start heading off the chart, and flashpoint dropping near the operating temperature of the oil.
As for cost, this oil is less expensive than the Motul I was using previously. At this point, BioSyn has greater than twice the life expectancy of 502 oils and is less than twice the cost of the least expensive 502 oils. 502 oils generally range from $5 to $12/Qt in price. The most expensive BioSyn blend is less than $10/Qt. So from a cost/OCI point of view, Renewable Lubes Biosyn is the least expensive alternative. If we look at wear and engine cleaning performance, then it just blows away all other oils, IMO.
