Quote:
I would give the Redline 5w-40 a try in your engine.
98, I appreciate the suggestion. 11 months ago I might have taken you up on it. In fact, Terry Dyson suggested Redline 5W-40 as one of the oils to try in my engine, before we had done any testing. But, since it was not Audi approved, I was reticent to use it.
Since that time, we have performed extensive oil testing on multiple RS4 engines. Terry understands quite well what the engine is doing to oils and how to engineer the oils to combat those issues. At the point that we had basic understanding, we went through a series of controlled experiments with my car as a test mule to confirm some of Terry's theories. At any point, Terry could have suggested that I use Redline. He did not.
Once the Terry's theories were confirmed by testing and by some research, I gave approval for him to either suggest or develop a no holds barred oil for the RS4 FSI V8. This took us to Renewable Lubricants, who had the leading edge chemistry and formulation capability necessary to develop Terry's oil ideas further.
Which brings us to this point 11 months later, and 10K miles into testing the BIOSYN 5W-40. Using this oil has dropped fuel dilution by better than 2:1, has increased oil life by 2 or 3:1, and has dropped iron wear rates by 3:1 or better. This has been confirmed in multiple engines. Now I've looked many UOA's on BITOG, and I've seen increase OCI's, but I've never seen such a dramatic decrease in wear rates as I have with this oil.
Happily, I'll stay with BIOSYN and will work with Terry to tweak the formula. After 10K miles on the initial 5W-40 blend, I am now running a test of some modified oil, which Terry believes will perform even better. We'll see!
