Originally Posted By: SlugGunner
Hi, I'm new to these forums but have been an automotive tech for 50+ years and retired as an ASE-CMAT (Master Tech) in '94. I'd like to clear up a misunderstanding on the 'purpose' or the THERMOSTAT in modern auto engines.
FIRST, it DOES NOT control or regulate engine temperature in an engine. It is only a part of the TOTAL COOLING SYSTEM used in automotive applications. The THERMOSTAT's main purpose is to bring the engine operating temperature to NORMAL OPERATING TEMP as quickly as possible. It does this by REMAINING CLOSED until it's minimum (starts to open) termperature is reached. This contains most of the heating coolant within the engine block and preventing its circulation thru the radiator portion of the cooling system until this temperature is reached. This temperature is usually 295 degrees F on most modern gasoline engines.... this has been determined to be the minimum desired operating temperature for effective emission control purposes. This is also normally the minimum temperature at which the ECM control system goes into "CLOSED-LOOP OPERATION".
Most modern liquid-cooled engines maintain a normal operating temperature in the range of 210-230 degrees F. Once the THERMOSTAT opens, it has LITTLE FUNCTION unless the coolant temperature drops below its rated temperature rating (195^), at which time it will begin to close and raise the temperature of the coolant in the engine block again. During the NORMAL OPERATING TEMPERATURE RANGE the coolant temperature is mainly controlled by the RADIATOR, TYPE OF COOLANT MIX/RATIO, RADIATOR COOLING FANS and AIR FLOW ACROSS RADIATOR FINS. Ambient air temp and humidity also have an effect in both HEATING and COOLING.
Hope this helps clarify this issue.
But, to get back to the subject of this discussion.... yes, it is possible for synthetic oil to lower engine tempertures. Mainly, this is seen in OIL TEMPERATURE (especially if you have an OIL TEMP GAUGE). I have seen this be as much as 30-40 degrees COOLER difference in racing applications. It has also given WATER TEMPERATURE GAUGE INDICATIONS of 10-20 degrees COOLER at the same time and conditions. Outside ambient air temperature and humidity can CHANGE THIS EFFECT CORRESPONDINGLY.
I think you meant 195 degrees. The modern cars I've dealt with run right on the thermostat. My TL stays at 194 and has very, very little varience.
My GN stays right on 160 all the time unless I run it hard and then it comes back down to 160 very quickly. I have my fans set to come on at 165 degrees.
On many, the cooling fans dictate at what temp it runs which is what I think you were saying. The thing is, every one that I've seen will heat up to a preset temp, the fans come on, it cools quickly, they shut off, and it starts all over again. Where does a cooler oil temp help this?
I'll say again that the only way cooler oil will affect coolant temps is if the cooling system is marginal already.
I just so happen to have an oil temp guage on the GN and did not see a difference in the short time I ran synthetic. I believe it happens in oil temps but maybe since mine runs a huge cooler already the difference wasn't there.
I'm sure the OP was talking about his water temp, most cars don't come with oil temp guages.
