Valvoline Maxlife Syn Blend vs Maxlife Full Syn
Michigan
So I just switched to Valvoline Maxlife Syn Blend due to consuming 1qt every 3k miles. I have previously tried VRP with no reduction in oil consumption. The vehicle is a 2015 F150 5.0. If I keep my intervals to 3k-5k, is there any reason to step up to their full syn high mileage blend? I know their syn blend is quite stout, and am leaning towards thinking the full syn would be a waste. Thanks.
I’d use the full sun; but I have lots of Valvoline EPHM 5w30
The past 2 changes in my Honda, I've used Pennzoil Full Synthetic High Mileage. I don't pay super close attention to my consumption because I'll top off as soon as I'm a 1/2 qt low but like you, it's about 1 qt per 3000 and I generally change ever 5000. My consumption is definitely less with this than it is with regular Platinum or Platinum High Mileage.
I tried VRP also but only for 1 OCI and then it was out of stock and I wasn't that committed. so I just went back to Pennzoil.
I was going to put the Valvoline Syn Blend HM in my daughter's 08 Civic. It was $20/jug at WM. I flipped a coin and got ST Adv Full Syn HM instead for the same price. Any real-world different between using either of these? I highly doubt it.
That’s my thought now too. The ST high mileage full syn is a few bucks cheaper at my local Walmart, so I think I will use that going forward.
I used the Valvoline Maxlife Synthetic for many years in my 97 Buick Park Ave that has 105K miles on it. I'm sure it was good oil for lubricating, but it leaked past my valve cover gasket and possibly also from a seal. It was a minor leak(s) that lost about ½ quart every 800 miles.
It wasn't a big deal mechanically, but it was staining the concrete floor of my parking spot in a shared condo garage. I put cardboard under my car to protect floor, but that was another eyesore. It was embarrasing because most of my neighbors parked all around me have newer cars. I like my old luxury car, but the oil leak(s) were bothering me.
Several months ago, I switched from Maxlife Synthetic to Maxlife Blend and the leak was greatly reduced. Instead of leaking a small puddle, it then leaked only a few drops. Much improvement from Blend.
Earlier this week my valve covers gaskets were replaced. Hopefully no more leaks. Time will tell. I still have Maxlife Blend in it.
If you want to use a Valvoline high mileage synthetic, then I suggest using
Valvoline Full Synthetic Extended Protection High Mileage (VFSEPHM) because it's slightly thicker viscosity than Maxlife Synthetic. So (in theory) the VFSEPHM should leak less than Maxlife Synthetic.
However, Maxlife Blend is the best of the 3 for not leaking because its viscosity at KV100 (100C or 210F) is same as VFSEPHM, but the Blend is part (half?) conventional oil. Conventional oil leaks less because it's less slippery. i.e. - Conventional has less slipping past gaskets and seals.
Maxlife Blend has 2 advantages over Maxlife Syn in regard to less leaking. Blend is slightly higher viscosity and partially conventional oil.
Maxlife Blend has 1 advantages over VFSEPHM in regard to less leaking. Blend is partially conventional oil.
VFSEPHM has 1 advantage over Maxlife Syn, which is VFSEPHM has slightly higher viscosity than Maxlife Syn.
There are other high mileage synthetic oils with higher viscosity than Maxlife Syn and VFSEPHM, but I don't know how good they are because I don't know enough about them other than they have higher viscosity.
Castrol Edge High Mileage (synthetic) has higher viscosity than any Valvoline HM product. Castrol Edge High Mileage is better than Castrol GTX High Mileage (Blend). In tests I've seen online, GTX flows very poorly at cold temps. Probably Edge flows better than GTX at cold temps.
Pennzoil Platinum High Mileage has a thicker viscosity than any Valvoline HM oil. I don't know anything else about this oil.
Those two (Edge & Platinum HM oils) are the only HM Syn oils that have higher viscosity than VFSEPHM (as far as I know).
The above are all higher viscosity than Maxlife Syn. In theory, higher viscosity oils would leak less.
Quaker State and Mobil One HM oils are much thinner than all the above oils according to the published data/spec sheets of all oils mentioned.
I don't know anything about Amsoil or Supertec HM oils. If anyone could post their specs for 5w20 the OP might appreciate that. I'd appreciate seeing their specs for 5w30.
Probably not.
Red jug Valvoline is available as a 20w50.
From published data sheets.
0w30
Valvoline Euro 65, 12.3
5w30
Valvoline Maxlife Syn 60, 10.7
Valvoline Maxlife Blend 65, 11
Valvoline Maxlife Plus (blend) 65, 11
Valvoline Extended Performance HM (syn) 64, 11
Pennzoil Platinum HM Syn 65.5, 11.4
Pennzoil HM Syn 60, 10.5
Pennzoil HM Blend 70, 11.7
Valvoline Daily Protection Blend 70, 10.5
Valvoline Euro 74, 12.4
Quaker State HM Syn 10.8
Quaker State HM Blend 68.4, 11.1
