Changing recommended oil grade
Tjulo
I own a 2014 Grand cherokee V6. Recommended oil is 5w-20. As I live in the tropics where ambient temp. is between 20-40 degrees celcius all year round. Can I change the oil grade to 5w-30 or 10w-30. It seems to me that I can even use single grade 30. Can somebody comment?
In Honda manuals, viscosity is recommended and not specified. Look at the section that lists all fluids for your car
I appreciate your pointing this out. This is what is shown in the "Specification" portion of the manual.
That is a Honda manual he's showing.
The manual is ambiguous - "recommended" used at the top, and "Specified" used at the bottom of the same page.
I guess you can't split hairs with that one.
Find the same manual on honda.mx website, and all of a sudden you will see 5w-30 there
Dont know, but it should not matter unless you believe they make different engine for mexican market
That’s the thing. It’s not about the engine really, it’s about the physics of film thickness and HT/HS. Engines can be designed to tolerate thinner oils without excessive wear, but it doesn’t preclude the use of a thicker grade. Insufficient film thickness is what causes wear and possible damage.
Monograde oils can be desirable if your starting temperatures allow it. Multi-grade oils are a convenience, nothing else. But good luck finding a VW 504 00 monograde :)
I looked at using mongrade, or even 10W-30 - but it appears that the SDS shows there pretty much pure group 2 at best (not talking about boutiques that may exist). For example valvoline SDS on 10W-30 below? I did actually run this for a couple OCI. It was super cheap on Amazon at the time.
Now I understand that its really the formulation and I am in no way knowledgeable about chemistry, but it seems to me like the high volume grades - like 5W-30 - are simply better base stocks. I am more than happy to be told how I am wrong.
