This is somewhat in line with the Thermostat question posted by someone else, but recently a good point was brought up as to "Normalized Oil Temperature." I can only think that "Normal" Oil Temperature is between 200 and 240 Degrees in most engines. Was the Comment on some days past Thread regarding "Plenty of Engines not running at Normalized Oil Temperature with Oil Way too Thick" made to explain the formation of Sludge? Or, that Oil must be the correct Grade to the Temperature of the Engine?
Or is this a case of the Temperature will be the same, regardless the Grade, so it is selected Otherwise? -30? -40? -50? And im still amazed at the -20 choices (Logic being 30 turns into a 20, 50 turns into a 40, etc at Temp, "Shears") - ? so "20" does not Shear to a "10?"
This concept of "Normalized Oil Temperature" Intrigues me, as it relates to Selection of Oil, specifically Grade, not so much "Synthetic" or Base Stock selection.
Any Info along this subject of Oil Temperature vs Oil?
