I've been running Amsoil ASM 0w20 in my tundra for 6k miles now, and i'm concerned whether or not it is protecting the motor like it should. I do plan on going extended OCI with the truck, but i want to be sure i'm using the right oil.
Can a 20w actually protect well enough for towing? Or should i consider going to a 30w like the ASL or the SSO?
The truck is an 07 tundra w/ the 5.7 all aluminum motor and has excellent cooling system's. ( Oil cooler, etc...)and never runs hot even on the hottest days towing 10k+.
The motor is highly technically advanced with 4 cams, dual vvti, and has 10 oil jets (i beleive)to name a few.
I know it's more critical with an aluminum block that it keeps plenty cool, and going off what i've read a 20w has better cooling properties than heavier weights, but at the expense of pretection, correct?
Any comments much appreciated.
P.S. UOA coming soon.
