I have a supercharged Dodge Viper with 16,000 miles. The SC has been on for about 2,000 miles. 670 rwhp, 650 rwtq. I'm looking for the proper engine oil and possible additive to use.
Here's why I'm considering the change. I recently had an oil dipstick and an oil pressure sensor break on the same day causing me to panic. I got the car home and once in the air discovered the oil pressure sensor had broken. Bear in mind neither was broken the day before when I checked the oil and drove the car. I decided to pull the pan and check some rod bearings. The first to fail in these V10's is usually #2 and #3. To my surprise all the rod bearings had much more wear than expected. The crankshaft was untouched. I installed new bearings and we're back on the road with great pressure 100+ psi cold and 75 psi hot.
Several knowledgeable people have looked at the old bearings and said 'Heat and oil starvation' (I'll try to post a photo). I have always used Mobil 1 in the motor and change it every year whether I've driven 100 miles or 1,000 miles (cheap insurance). Everyone has a different opinion about what to use but I was told all the answers could be found here. GREAT Website by the way. Wish I had seen it years ago!
Obviously what I'm using isn't giving the engine enough protection or the wear happened before I bought the car with 10,000 miles on it. I don't drive the car much but every drive I take is hard and fast.
I tried searching this site but didn't see any close comparisons so here I am asking questions.
Thank you in advance for any recommendations that you might have.
Sal
Now I'll try to post pics.
Sal
