- Joined
- Aug 9, 2022
- Messages
- 144
I purchased a new set of Mopar lash adjusters for a 2015 Pentastar 3.6L, and notice that out of the package the plunger is rock hard, and they seem like they are fully extended. Is it necessary to release the oil pressure from these lash adjusters and partially depress the plungers so they are not installed fully extended, or are they designed in such a way that they would self bleed and shorten up to the correct length once the engine is running if they were too long when initially installed?
The service manual states that they should be at least partially filled with oil, but then in another section states to fill them with oil before installation. I don't see any mention of checking installed length, however, I have come across some general engine information that isn't Pentastar specific indicating that valves could be held open partially if the lash adjusters are not bled down and partially compressed prior to installation.
