Ecobee. Stay away from Nest.
It’s pretty legit. Like it a lot.My electric utility offers a Ecobee for free. How do you like yours.
Yep. Ours basically bricked itself after 2 years, would show it’s connected but then freak out and say it’s not connected. Didn’t like that I couldn’t set the fan to circulate air randomly either.Ecobee. Stay away from Nest.
Our tool and die guys at work do the same for their office lol… my smart thermostat was not bought with any utility rebates so they have absolutely no say over what I do with it nor do they know I have one.Aside from these thermostats the utility can control, hotel thermostats are the same. Woke up sweating and threw the thing on the lamp just to get some cool air and sleep.
I have a LUX thermostat too, 7 day programmable. I use it in the manual mode. Main reason I like the LUX is because it has adjustable temperature swing or differential. As far as I know LUX is the only brand that has that feature.My LUX thermostat seems to run off the 24V the furnace gives off. The AA batteries in it carry the programming through power outages, and last a really long time.
Many allow this, buried in the programming though, typically under the "installer" programming but not always, Ex. Many Honeywells allow this.I have a LUX thermostat too, 7 day programmable. I use it in the manual mode. Main reason I like the LUX is because it has adjustable temperature swing or differential. As far as I know LUX is the only brand that has that feature.
How come?Ecobee. Stay away from Nest.
I have had a couple of Nest thermostats although I haven't switched the dumb thermostatus out at our 2022 build house yet. I will eventually.Older programmable for us.
My utility is offering a killer deal on smart thermostats. Other then the cooler looks I don't think we would benefit much. We are on different schedules and don't have a set number of hours where we are both sleeping or out of the house to allow lower temps. I don't use the programming now as it is
So which do you have? Name of smart thermostat and if you like it.
I have that one too. Mostly because I'm not home 3 weeks out of every 6 so it'll alert if the heat isn't working.We have a Honeywell T9 for the sole purpose of once I’m comfortable in bed I am not walking back downstairs to change the thermostat if I deem it uncomfortable. Other than that, it’s on a temperature “hold” 24/7, which means it otherwise operates as a basic dumb thermostat. It does log runtime and tell me when the filter needs changed. You can also change the filter change interval, based on “days of runtime”.
I can also set the fan to “circulate” mode which will turn on just the fan on and off occasionally to move air through the house. That alone has helped tremendously, with the other thermostat you had off, auto (fan would only kick on when it calls for heat/AC), and on (fan runs constantly). The upstairs would end up boiling hot, ground floor fairly comfortable, and downstairs pretty chilly in the winter regardless of the season.
I can also compare years. Last year in July the average high in my area was 76F with 5 days of rain, 15 days of cloudy, and 11 sunny days. 2023 was an average of 77F, 4 days of rain, 6 cloudy days, and 21 sunny days. But I cut my AC usage by over 30 hours by tinting the windows in the front of my house that face east.
Very problematic.How come?
I haven’t had any problems I’ve used it with google home and now on Alexa all integrated just fine. On the hardware side or software side you find it problematic?Very problematic.
