For lug nuts, spark plugs, and valve cover gaskets, I use the correct torque spec. The places where it's most critical get the spec torque, while everything else just gets whatever I feel like using
That is to say all fasteners do, but not all procedures give a torque because it is just not critical in some applications.I am not sure everything even has a spec. I have a the 3800 factory manuals and the LS1 factory manuals and some items don't give a torque.
The idea of engineers needing to come out with a recall of a recall to fix the first initial problem is also frightening. Yet here we are, all riding in these “death machines” down the interstates at 75mph.The idea of a "mechanic" "having a feel for it" is frightening. That means one mechanics idea of "tight" is not the others idea of "tight".
You are not like the engineers I work with when I generate procedures. We even have a statement that says "Tighten fastener using good shop practice"They get away with it but it's not the standard principle practice nor should it be.
It sounds like the wild west in those shop's.
Good shop practice? at work we have a document that spells out what torque what each bolt size should use, with allowances for materials, and disclaimer about how this spec can be overruled by the spec’s for the item(s) in question.You are not like the engineers I work with on submarines when I generate procedures. We even have a statement that says "Tighten fastener using good shop practice"
So what you are saying is it is necessary to torque every fastener, to spec, on a car?
Do you know what that wording means when you write it?You are not like the engineers I work with when I generate procedures. We even have a statement that says "Tighten fastener using good shop practice"
How many BITOGers even send in their torque wrenches for calibration every yr or 5000 cycles?
My small torque wrenches are snap on and have never failed our ISO certification / calibration check that we had yearly while I was at a dealership.How many BITOGers even send in their torque wrenches for calibration every yr or 5000 cycles?
The achieved torque can also vary depending on the condition of the fastener and operator experience. If an inexperienced operator does not slowly reach the desired torque value (esp when using a clicker style torque wrench), they may be well over spec.
If you’re interested in a more technical conversation, there is a lot of good content in this thread:
https://bobistheoilguy.com/forums/t...in-for-using-torque-tools.158112/post-2322802
Thank heavens you don’t work on my airplanes.I’ll torque wheel bearings if they need to be preloaded but not much else regarding suspension just usually run it down with my impact or ratchet.
GA is really a minefield.Thank heavens you don’t work on my airplanes.
axel nut, lug nut, head bolt, + an odd 1 here'n there. I've been told I havea tq wrench in my wrist but what I do w/all - is tighten according to size. The ones listed R4 safety (customer wants a rotate, I take off 4a break job... I hit the lugs as last man to touch it is man liable to any 'not-so-good' dwn the rd. Rebuild a motor? a blown head gasket will not B a claim (legal/financial) mine.I have wrenched on lots of vehicles for different things and the only real torque to specs I have done is for wheel axle nuts.
Most other things I snug down tight with a hand ratchet or wrench and call it good. How about you?
Pretty sure I’ve dropped mine on the floor at least once a year… does that count?How many BITOGers even send in their torque wrenches for calibration every yr or 5000 cycles?
Most calibration shops have repair services...Pretty sure I’ve dropped mine on the floor at least once a year… does that count?
That reminds me, I need to replace mine, its been missing at least one of the screws for a few years now. (then again, so am I.)
Not taking a HF special in.Most calibration shops have repair services...
