The rotation and movement is what probably helps with keeping them clean and also delays in development of wear patterns which keeps the compression in spec for longer.
Could be, that scenario is somewhat common with GA aircraft engines. I've experienced it on aircraft that I've owned, some more so than others.Sometimes someone will post that an engine suddenly used oil. Then mysteriously quit using oil. Did the rings line up for a while?
I suppose that will result in very even wear and ring width should be very consistent over the lifespan of the rings.The way I understand it they are all over the place CW/CCW, faster and slower and a more aggressive cylinder crosshatch pattern can increase the movement.
I read that paper a long time ago, they used radiotracer technique to observe rotation.
https://www.jstor.org/stable/44548521
But they do. And it's a good thing that they do?No way the rings in a car are rotating at up to 8 rpm.
https://www.partinfo.co.uk/articles/292What proof do you have?
Sorry, the link is in the title. Also the YouTube video posted by anther member, earlier.In the early eighties' all of my family lost their jobs within a few weeks. We opened a car repair business and did quite a few engine rebuilds. Older low value cars were, if not too worn, fitted with AE Hepolite oil control piston ring sets. The top ring had a 'ridge-dodger' profile to clear the cylinder bore's unworn portion. Many other brands had a similar product.
They worked very well. Compression test figure
Not case closed 'proof' by any means. I'll look at my notes & bookmarks tomorrow evening. I've spent the last four hours struggling to remove a single Tork bolt from BMW E36 starter motor. Now I know why I've been putting the job off since 2020Thanks for all of your replies.
But why do they rotate?Yes they rotate...not sure where people get the idea that they don't.
A piston on the power stroke will compress the ring unevenly owing to the effect of the thrust side causing a ring to naturally rotate as the ring's gap is nearly always at an offset angle to the thrust?But why do they rotate?
My guess would be the combined effect of the cyclic gas
slightly off topic here- but some big mining companies in Australia decided to sack their truck drivers and run driverless trucks - with in a few weeks there was deep ruts in the dirt mining roads and enormous problems when the rains came - the good old human drivers "wandered" over the road way and kept the whole road compacted evenly. the stupid AI dimwits ran all trucks on exactly the same track and destroyed the roads, especially for the other smaller vehicles running around the minesite. such stupidity going to robotics en masse and depriving kids of good old simple jobs manufacturing and driving. such managerial arrogance is the death of a good living for many people.Many years ago when Cadillac switched to robotic assembly of engines the robots were designed with software that put all of the gaps in the piston rings aligned. The result was that a batch of engines was produced with the gaps all aligned that had very high oil consumption. It was so bad that Cadillac had to do a recall and the fix was that the tecks at the dealers had to take the engines apart and rotate the rings on all the Pistons so that none of the gaps aligned. Imagine having to rip an engine down just to access the Rings to change the positioning of the gaps. But that is what they had to do. Of course they change the software from then on so that whenever robots assembled the engines the gaps in the piston rings were no longer aligned. So I guess the Rings don't really rotate that much because if they did the problem would have gone away without having to rip the engines apart and redo the positioning, and it didn't.
https://www.sae.org/publications/technical-papers/content/2019-01-2366/What proof do you have?
That's coolYes they rotate.
