Originally Posted by Ws6
Isn't the 328i $40-45K stripped out and $50K or so normally optioned?
BMW shows the current 2020 330i's starting at ~$40k. Pretty nicely optioned as well, sticker on my 300 when new was $40K and didn't come with forward collision warning/stop, lane departure, or panoramic sunroof as standard equipment. Optioned up as similar to mine, but with WAY more options, because it's a package, brings it to ~45k.
The new 4-cylinder BMW's are legit nice. I looked at it, and yeah, it's good stuff. I'm just scared to own one due to maintenance/reliability long term. Otherwise, an X3 340i looks super neat. Scared of that though, and the X3 and X1 just weren't any better really than the CX5 turbo in any way I cared about, so I skipped the German thing once again.
Maintenance is nothing.
Historically there are two or three common and potentially costly repairs within the first 100k miles:
#1 Oil Filter Housing Gasket. Jury is out on the B-series engines. (X3, B58 I6)
#2 Valve Cover Gasket.
#3 Electric water pump & thermostat. Tend to fail sometime between 50k and 100k miles on the N55 I6. B-series are a little different in this regard. The water pump is mechanically driven but the electronically controlled thermostat is part of the pump assembly so you can't replace one and not the other. There do not seem to be any widespread failures.
Someone commented that BMW's are assembled as efficiently as possible, but that efficiency comes at the cost of disassembly for repairs. It can take a lot of time removing parts to finally reach the part you want to swap out. Due to the amount of time invested a shop will suggest to replace some parts pro-actively which drives up the cost. An example would be replacing the valve cover along when having to replace the valve cover gasket. The job will run about $1,000 in labor and the gasket is $45 whereas the valve cover kit is $500. The labor is high because by the time these parts fail the plastic connectors (like all makes) on all the stuff you have to remove have become brittle so you can't just rush it.
DIY can save you a ton of money on repairs.
