Do SP oils have more/better anti wear additives over SN+?The main benefit, as far as I can tell, to using SP oil in an older vehicle is if it has a timing chain.
In what way is an SP oil more beneficial to a timing chain than an SN or SN+ oil?The main benefit, as far as I can tell, to using SP oil in an older vehicle is if it has a timing chain.
That’s part of the SP specification.
SP will be backwards compatible with all the previous classifications. Is there something that bothers you from running the latest oils?
Simple answer is no you don't need SP oil, but it is better or equivalent in every aspect.
So the real question is why not?
From Kendall:
10 year old Camry?
That's THE car for clearance oil. If it's on sale, pour it in!
Not even sure why all this investment into new oils and such when the whole transportation industry is moving towards EV's and H vehicles.
