diy ,powerful laptop wifi antenna..
I finally got a card. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180425424251&ssPageName=STRK:MEWNX:IT Now,where do i get a male to male connector for this?
anyone?
Not sure what you are asking for - there is no "male to male connector" needed for a PCMCIA card.
You just plug the card into the appropriate slot on your laptop and fire it up...
If you can find a "ham fest" flea market near you they'll hook you up. Even vendor tables that don't sell that stuff are freindly and will know where you should go, as they mostly case the whole joint themselves before the gates open to the public.
Originally Posted By: StevieC
I'm currently using an Arizona Iced Tea Can (Long & Cylindrical) on my Asus router around the antenna and I have boosted the signal by 1 full bar using the standard 70mw power setting in the routers DD-WRT firmware. I upped it to 80mw along with the can and now I have virtually no noise and a very strong signal. I get the "Excellent" signal strength reported by Windows anywhere in my house and the router is in the basement next to a concrete wall.
So what did you do, slide the can over the existing router antenna?
