OK! I bought the "Ultra copper" Permatex "Gasketmaker." So have that all ready to go. So i just pulled off ALL the tape (yes, melted duct tape) .. and i discovered a disconnected wire! In abswnce of an immediate photo (I can snap a photo,) the wire is as follows:
Passenger side of engne bay, looking towards drivers side. Right behind the alternator, the wire appears to be a singular wire, with a (partially melted?) two-prong connector. Looking further back on the wire, it appears to be "Green." It then joins the same wiring "tune of wires" that appears to go back to multiple sensors, all jammed in around an "Air check valve" - which is wherei lose track of it. Im not sure what this wire is, where it goes, or what it does.. but its moderately possible it as something to do with SUPER running rich, start/stall, fuelish use, etc (TPS wire? idk!)
I can maybe snap a pic, unless someone knows what this is. 84 Camaro, 2.8L V6 carb's, Auto.
Thanks! And im about to go back to the parts store too, with the "Check valve" so i can measure.. if i buy a fitting, maybe i dot need to "Block it off" with RTV, a penny,, BBS, a pipe cap.. maybe i can get it on as intended with a fitting. What would you do? Block the flow, making it only LOOK functional, but in fact blocked on both sides of "Air check valve"? Or reinstall for air flow, as intended?
Thank you!
Here is that wire. taking pics of "both sides of the carb" within the hour...
Here are the pics of the wire. Its "green" under the wrapping.
Thank you!
